cable path simulation moving
  • Thread starter Thread starter andri.can
andri.can
Hi, I should simulate the behavior of an electric cable in a set of a pantograph hinge door that I simplified with sketches. I would like to keep the cable and its sheath (metal wheel) driving with "horses" and folded plates, but I don't know what way to follow to create the flexible cable that follows the door movement. in the attached axieme I have inserted two circles of magenta color that represent the starting point and arrival of the cable tract. the cable path is not all exactly on the basis of sketches, but variations along the z axis are negligible.
Thank you all for your help!
Bye.
I pull the cables like this, see if it can be useful.
referencing the various sketches to the moving parts, the cable path is updated to every regeneration.
thank you for the answer, unfortunately I can't open the file because I use wf3 (please if I didn't specify it in the message). I try to do the sketch that drives the protrusion of the cable with references connected to the moving parts, but there will be parts that will have to be flexible; for these parts how do I adjust to the parameters of flexibility?
If you can send me the file saved with the previous version, thank you.
I'm sorry, but I don't have a chance to save the prt for the wf3. However to make the cable flexible enough that the protusion sketch, giving it the appropriate references, follow the movement of the various pieces.
