LaboratorioDieci
I did a test with the same technique, and it works well. the only exception I find is that the fitting spiral comes out well with 1/4 lap, otherwise the segments are interwoven.I tried to use the spiral as last stretch and you can make a unique body.
for the length of the cable I think it is enough to measure a winding + the stretch that makes from bridge with the next one, that is spline or spiral, and to get them how many windings you have to do.
assuming a step of 1mm the length of a winding will be about 314816 and consequently to make 1600000mm it will take 5 windings
the length theory of a winding works to a certain point, since the windings are not all equal. If you want to measure the complete winding you can make a curve composed of all the segments helical/spiral and then measure it with evaluation/measure
