calandra lamiere da 6 metri
  • Thread starter Thread starter Giacomo Lepore
Giacomo Lepore
Good evening to all,
I look for in the campania area someone who can roll up to 6mm thick, and up to 6 meters (even if possible).
Unfortunately my contacts arrive at 3m.
Who helps me?
and if I relaunch the "campania" bond?
Thank you very much.
hi jacomo, in cesena there is the davi, one of the major producers of coves and bending machines. try to contact them, they may have customers in the country with the machine suitable for your needs.
If you have to look for someone, I recommend you as it did maxopus to hear the producers.
number one x detachment is faccin,
Then give,
then to wheel are mg, rock, etc etc. etc. etc.
feel them and see if they have any clients in your area. .
p.s.: 6 meters are a bit many, I in the past bought material calandrato, up to 2500 if not mistaken.... maybe you will have to move in Italy to find something. .
in the world in general it is not easy to find a carpentry workshop with a 6m grill. instead there are the piping plants that produce calandrated and welded sheet.
example the arvedi piping plant or pipe padana has all the systems to make from sheet metal in rolls, smoothed, cut, bayed and welded.
I would advise you if you have to make pipes of 6 meters to fold them spirally, also because you would have enough a machine even from 1500 and you are less bound with the minimum diameters.
es: a roller bar of about 130mm in diameter and 1500mm in width can reach up to 6 mm otherwise the diameter on the bending axis will be greater for the bending of the rollers (fe237jr not aisi 316)
without knowing how to read or write I would say that to reach 6 meters of length sp6 descend under the metre of diameter is hard.
p.s. at the davi I was there and they built calandre thicknesses 60mm on 4 meters so it is likely that he can really find someone who does to your coem would lighten before. In such cases I would have opted for a flag fold, I think you can do it all.
for my experience at the flag fold I folded up sheets up to 3 mm and it could be done, but the 6 mm I think when leaning on the banidera opens the previous folds.
