Calculate tablets volume
  • Thread starter Thread starter SpikeCAD
SpikeCAD
Hello everyone, I'm new in autocad. thanks for your support and for the excellent environment you have created.
from pharmaceutical technologist, I would need to get the volume of a tablet. I designed the tablet exactly for how it is measured, with autocad 2015. I can't calculate the volume with measuregeom.
I'll attach the defendant file in case you want to take a look at it.
Thank you. View attachment Drawing2.dwg
Well depends on how you drew it (I can't open your file being in 2015 format)
if it is a solid, just the _massprop command. if they are surfaces... Ciccia.
... the more time passes and the more I amaze myself. 10 days ago a accountant wanted explanations on autocad. Now he asks for a pharmaceutical. . .
autocad is becoming like the smartphone... There's technology and what he says "is bad, doesn't have the keys..." :biggrin:
Thank you. View attachment 40223
you have created the tablet with the surfaces, go to the surface menu and use the command sculpt surface (sculpiscisuperf) will be created a solid that will remain inside the surfaces, move it and then, as crystal says, uses _massprop to obtain the property of the volume.
in your file only 2 surfaces were visible.
closed properly here is the tablet.
more than autocad I was in you would look at explicit cad, for the within where you are can give you a lot of + (always that the pharmaceutical is your area)
