calculation displacement in halfway [sdc]
  • Thread starter Thread starter reye
reye
hello to all, how do you calculate the displacement in halfway of the structure reported in the annex? Is there any form to refer to the above calculation? on a test carried out by my professor calculates it as the maximum shift and does not seem correct.
use the method of the elastic line.... practically impose a series of differential equations of simple resolution. . after which you find the equation of the shift according to y (ascissa on the axis of the beam) calculate the derivative and find the maximum or minimum point. . .
it seems difficult but it only takes 2 minutes
The maximum arrow is:
f = rdq*m*l^2/(27*e*i) = 0.064*(m*l^2)/(e*i)
I found it with the elastic line and then found confirmation on a manual of mechanics.
but in the case in attachment the maximum arrow does not fall in half-carry.. Am I wrong? Isn't he decentralized?
