calculation of areas
  • Thread starter Thread starter ars
ars
Good morning, everyone. I should prepare a concession I would like to use the plant of the areas to prepare the tables. the areas of porch balconies etc. should be considered halfway, but the area labels consider the entire surface. Can someone give me advice on how to do it? Thank you.
to put the surface in half...it puts itself whole and in the calculation of the charges the reduction parameter applies.
Bye.
the area parameter is a read-only parameter.
you can provide a "text" parameter to type manually.
Instead, the value can be managed in the abachi, by creating a "calculated value"
As for the graphical app instead I can bring in retino that highlights the area in the foreground. (even above the walls) using the low level of detail this does not happen there is a way to do it without having to switch to the high detail definition. Thank you.
command: annota>region>region and select the perimeter of the premises . assigns the appropriate sampling
I used the color filling scheme but where there are the walls remains below even if in the properties of the view I put in the foreground. Maybe I did something wrong?
to display the color legend to the limit of the area you must hide the walls from the specific view
