calculation of bending sheet metal
  • Thread starter Thread starter PiegatoreSolidworks
It was corrected, in the previous model because of the 2 sunshades the bending moment was absorbed only by the two pieces of sheet remained on the sides of the bench, while now working all the lower part of the sheet. post also efforts (vonmises)
Certainly!
without the sunflowers is definitely better... Even the equivalent tentions are below the yield (you have a safety coefficient of 1.4 with 300kg applied vertically).
The only thing I would raise the base, to avoid accidental tipping of the bench if not bound to the ground.. .
a curiosity the bend relative to the knee area as you would realize it?
the answer is simple: in the workshop we have, a mold made by us, with round punch and a matrix with "u" section. I also have a curiosity....: how did you determine the safety coefficient of 1.4?
I'm sorry, but first I don't know I wrote about the windws calculator... will be the late hour:)
the safety margin thus calculation:[sigma(snervamento)/sigma max(Vonmises)]-1
in your case is 235/140 -1 =0.67 means that you can increase your load by 67% before you get to yield... to mean 300kg*1.67=500kg or 500kg your structure is permanently deformed.
Thanks for now, I think I understand something more... I'm gonna go to bed tomorrow and I'm gonna bend my hands over the plates. Good night.
I begin to understand something...... just but always better than nothing! 117mm shift is in the modified bench that I didn't post you and do now....if you can tell me if it is correct as value?
Thanks early, Marco.
I have seen that you have already solved however maybe it can be useful to you, if you click where there is the scale with colors and the various measures opens you a manager of the "Legend" where you can replace the "scientific" reading method with reading in millimeters or other, I find it clearer and faster.
Thank you, I didn't know about this. I'll try.
