Alarast00
Hello everyone,I would have the need to calculate the section of the slot shown in the attached images, the purpose is to be able to correctly size the flow of a fluid that crosses it. the slot is obtained by a non-passing hole with a tilted round tip (hole.jpg) and then intersected with a cut obtained by a disc cutter with triangular section cutter (cut.jpg). can you use solidworks to measure the slot area?
