calculation supported beam
PaoloR1
with inventor professional how to make him do the analysis of a supported beam. I found the way, fixing one or both ends. but if it were supported How do you do that?
thanks and hello
Palo
support is hypostatic. we have a good hinge and a cart. there are tutorials on the web
mechanical quotomg...if for supports you mean two trolleys that bind it vertically, then the beam is labile, remaining allowed the rigid motion of horizontal translation. . .obviously the thing is indigested to the calculation programs, while it is instead known that, in such condition, the balance can exist as long as the system of forces charging the beam performs virtual work null for the rigid shift allowed by the constraints... i.e. if the external forces agents on the beam have resulting vertical.
Hey, guys.
Mine is just a curiosity about inventor. I actually have a little x-calculating program, but I just wanted to know how to do it with inventor.
this is the example I used for an application to a customer:trave.webp Here, I was wondering how to get the result with inventor.
Thank you and hello to everyone.
Palo
