gil
Hello everyone
I'm with this problem. I have a glass wall (all glass) fixed on the 4 sides with size 1600 (base) x 2400 (height) mm.
must resist the pressure of a crowd of people equal to 300kg on linear meter at 1 meter height. then the pressure is applied on an imaginary line.
what kind of glass and thickness should I use to ensure this resistance?
Currently, you also know the typical characteristics of the glass because that encapable of the glassmaker does not know what it sells and therefore I have to see if I remedy this value, for the most common types of glass.
Can someone help me?
