now for the 3-axis processing you use? ?The problem is to find a cam that doesn't cost me a kidney:biggrin:
a car owner cam, which I recommend :36_1_10: and since my judgment is heavily negative for part 3d, I don't say what it is. .now for the 3-axis processing you use? ?
Maybe I didn't explain well. I am certainly convinced that they can do but the sense of my answer was “it is more complicated and expensive to build the fixes that perform the processing itself”, as to say that the processing has nothing difficult.hello to all
the thing is easier than you think...at the level you fix certain
the rough is bigger than the finished piece and is worked twice leaving an unworked part to leave it fixed to the rough
the cam I use is 3 axes so now these things we do to 3 axes...
but for the future there is an idea of 5 axes and these processes I would like to make them all the time. . .
instead of “....because the asked....” read “....because you asked....”.Maybe I didn't explain well. I am certainly convinced that they can do but the sense of my answer was “it is more complicated and expensive to build the fixes that perform the processing itself”, as to say that the processing has nothing difficult.
and then apologize if you do it with the 3 axes because to the asked if you can do with the 5 axes? It's like you want to buy a ferrari and ask if it can go to the speed of the ypsilon lance you already have. So the question itself meant that you should have done everything from the beginning.
