cam
  • Thread starter Thread starter valeriob
valeriob
Good morning, everyone.
Can someone help me use cam coupling with sw2008? :confused:
I'll explain better.
I created a pin (extrusion of a ø) with the intent to use it as a pointer, then I created a base (extrusion of a ø) round with a hole in the center on which I got a simple path (a profile + offset) with extruded cut prondo 20mm; together, when I go to select a face of the cut route (select tangency) and the face of the studle as a tip, automatic confirmation ? ? ? ?
thanks to all.:finger:
If you post your file you might understand where and if there is error.
from how to explain the procedure would seem correct and if I understood correctly it should be like this that I did quickly:
View attachment TANGENZA.zipTANGENZA CAMMA.webpif you have 2009 you can see and try the axieme file that works well to me and does not give problems.
you probably have some "irregularity" in the sketch of the cutting of the cam which is obviously not recognized as a unique surface.. I don't know, check.
Mar
