can anyone help me? ? point and comma problems.
  • Thread starter Thread starter dsp
Status
Not open for further replies.
dsp
Hello, guys.
after having successfully installed rhinoceros 5.0 (64-bit) , the following writing appears:
yuor setting are using "." for both the " decimal point simbol" and the "digit grouping symbol".
will his causes a number like 1,000.5 (or1.000,5) to be identified as 1,000.5 and causes serious problems with our program.
please adjust yuor region / international settings for yuor operating system to make sure that these two settings are not using the same character.
which translated with the google translator:
setting your are using "." both for the "simbol decimal point" and the "symbol grouping digits".
its will cause a number like 1,000,5 (or1,000, 5), it must be interpreted in 1,000,5 and cause serious problems with our program.
Please adjust your region/international settings for your operating system so that these two settings do not use the same character.
I have understood that it is a question of point and comma but I do not know how to act extra, example, in the table of materials does not change the values.
Can anyone help me? ?
Hello, guys.
It is not a matter of point and comma, but of point or comma.
Basically, you messed up with international window 7 settings, and you set up as a decimal separator and also as a group separator of digits above 999, the point." "
Of course, rhino doesn't know that fish sieves,
if you have windows in Italian language, not to let it go crazy modifies international settings by putting as a separator of decimals the comma and as a symbol of grouping digits the point.
from windos control panel select
1) international clock and settings
2)from the first tab press the button at the bottom "additional settings"
3)first tab numbers and impose the comma on the voice "decimal separator and the point to the voice"regrouping digits"
see pictures
Status
