Sasso SP
are to ask you advice on how to optimize the modeling process for car tuning.
Recently in the company where I work we started working on aesthetic modification of cars already in production (tuning).
the process I use is very simple, scan the body shop reverse engineering on it and subsequent modeling of the new shape.
the program used is v5 using the modules supplied gsd and fs.
I usually reverse with sections and lines, even if I find it difficult to go to do the right subdivision of the surfaces, then I start to model creating a lattice of curves on which I will go to edit the surfaces.
to make the lattice use the classical sketch modeling, combines and some 3d spline (fs) being that in this phase the priority and style of the curves becomes very difficult with this type of parameterization to be able to easily change the lattice.
the final part and that of smoothing the surfaces where there are imperfections through the local modification of the individual surfaces per points.
I want to point out that I am not a designer, I worked for 3 years on body shop however in another firm and with different processes.
