marti81
Hello, everyone. I just joined this forum hoping to get a useful advice. I'm a civil engineer and I've been working on offshore structures for a couple of months. I work in London. My problem is as follows:
- imagine having an auction (not folding and always subject only to traction). I have to have two hinges to the two heads that allow me to rotation at least 35 degrees in all the vertical planes that have as rib the vertical passing for the lower head of the rod I thought to adopt two cardanic joints to the extremes. I realize that use is improper. I would like to know if first of all the cardanic joint can meet the requirements described above thinking that the lower joint will have an arm always firm and unable to rotate. the other arm will be constituted by the auction reached by means of the two pins and the cruise that characterize the cardanic joint.
If the answer is yes, I would like to know if it is feasible to these conditions:
- traction effort: 15000 kn = 15000000 n
- the first joint will be located at sea, at a depth beyond 100 m, while the second at a 20ina below the surface: I have good guarantees on its durability under such environmental conditions (salt water and sand) and no maintenance?
if you think you can make me give me references, directions, norms on how to design it? I imagine that I need to design the straffes in such a way that they do not collide when the main rod (it is a kind of rope) bends 35 degrees. the traction effort given is the maximum one, of course the joint will be subject to efforts of different intensity and in different directions, you understand well why. I think cmq that such joint can resist well fatigue.
I hope I've been clear and posted in the right section and I apologize if I didn't have to use the right technical terminology.
Thank you very much.
