Federico_992
good evening mechanicsmg are feder a mechanical passionate student I came across the excel file that concerns theUhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh ... try to count and see if you get the same
I've come across this excel file, I can't get out of it to calculate my facc.ruota, it could help me thank you earlier. greetingsc(resistente)=t*r+ fn*e It's the limit couple that if you get over it, you start slipping.
I attach here a summary card for a motorization of a cart like your 1000kg porata.
as you can see, setting the usual formulas in excel you can determine that you can make ramps from 0.8m/s^2 and if you try to make a fur more you get that wheels slip.
being a trolley that transfers things from one side to the other, especially in practice you do not go very specifically to deal with (e.g. you neglect the wheel inertia) and you go basically to evaluate two main aspects:
- torque calculation due to wheel deformation and then passing through fv- calculation of the acceleration torque that is discharged as force that is opposed to the tangential force of adherence t and that goes to sum up or remove the force of thrust fright to clarify all doubts:
- the cart weighs 1000kg
- the wheels in total are 4 therefore each wheel has 1000/4=250kg as vertical force
- the limit torque and the torque due to the turning friction determines it on the single generic wheel (motorized or mad that it is)
- the total torque above calculated serves the system, therefore to the 4 wheels but being that the motions are only 2 connected by single motor, it is has that the total torque of the system is to be divided by the number of moving wheels
- therefore the power dissipated by a wheel must be multiplied by the number of motorized wheels and divided by the number of motorizations that are realized (in this case a motor for 2 wheels...in other cases each motor a wheel)View attachment 50283
