cartigli e tavole
  • Thread starter Thread starter monster
monster
Aia aia... Is there anyone who can fix the tables and make the cartilage or import it?
I would need someone who explains how to proceed... I did something but I can't get the desired results hello people.. .
Yes, I do.
But you have to explain something.
I have a part file (grossino).
I did a lot of mview and then use them at the table.
I'll put it on the table. After hours and hours of work I realize I need a stupid terna.
I open the file part, I create the terna. I reopen the design and require updating (obvious).
I saved the part with the same active terna all the same except that I created a new terna.
After the upgrade many odds become "grigisters" as if geometries were changed!!! .
Can you "disassociate" the model at the table? How do you do that? Can you freeze the view as it is?? I can't stand the grayish quotas!!!!!! ! ! ! ! ! ! ! ! ! ! ! ! ! !
help please
dylan
hi tegolina ...time ago I had happened to myself to make a table and then find the quotas in gray death...I remember that I had associated the quotas to a skech or reference made with it and after changing the part then losing the constraints of the schecccccccc the quotas become gray dead and not editable....bah vallo to understand I am stumptrone
Hello tegolina
I don't understand why you created the "mviews." Usually they are used to make assonometry or splits of assonometry and not of orthogonal views to the axes.
did you quote on the mview?
Let me understand that maybe I can help you.
Say hi.
to "stack" the draw from the part/assieme you must:
1st create obviously the table and at least a view
2nd save and exit
3° rename the part/assembly from the Windows Explorer. attention
if you renounce the file from the toptron Explorer by going to take the file in question in the board branch (clicking on the "+"), toptron regenerates the links automatically.
4th reopen the previously created table. at this point, not finding the source file, a new window will open
5th click on "remember now"
6th at the opening of a new, downward, click "stack" then "save and open"
7th at this point will reopen the table but no longer having any connection with the file of origin. in this way it is possible to create additional derived views having previously (point 1) created a starting view.
8° from the Windows Explorer put the original name back to the part/assembly file (optional operation).
As regards having the unfair shares after the creation of a new terna is rather strange; You probably did some maneuvers you didn't have to do and as well you know toptron is quite susceptible:
Say hi.
hi, you actually rename to the coward with the uorcaraund you suggest you get the usual mask x reconnection. I wonder xke nn put the usual "disassocia" like that in cam files. x what about ke mview I need so. I have to quote several tilted planes (cam die) and need to create all the views in the cad.. no one then said that a mview view at table nn could be treated in the same way as an orthogonal view of the axes. I would also say that the system is susceptible.. dylan
I don't understand the problem. .
open a draw file.
you will have sheet/sheet1. click on +
dx button on "no" (cartiglio) and do "new cartiglio".
Now either you make a new one or you give one of the default ones.
I hope you came here alone, didn't you?
He better explain what's wrong with you!
Hello
dylan
exactly up to here are with editing and sheet selection
I want to import one already made!!!!!! porca.....lollla:rolleyes:
already done...
by whom?
Explain!! !
You want to import one that's used on another cad?
export the cartilage from the other cad in curves 2d.
It amounts in peaks on draw.
You draw on the imported chart for tops. Remember when you used to copy your drawings in transparency when you were a child? That's right. :-)
I don't know if you can do anything different.. I don't think. waitiam answers from the thousand magicians that populate the hole. ;-)
dylan
The only maneuver you can do to "import" a new cartilage is to rebuild it.
In the past I found myself in your own situation and ms gave me this answer.
but a maneuver, albeit slender, you can do it.
1st you care in the part the dxf file of the cartiglio (remembered in the import options to enable "model" and disable "sign")
2nd in the imported part you create a sketch within which you will import the geometries of the cartilage with "additional geometry" (cube with side face dx of purple color) .
3° save the sketch in "struments of the sketch--->export"
4th in the table, you know how to create the cartilage, always within the "sketch tools" you have the possibility to import the sketch previously saved.
5. Unfortunately, the texts must be handed over.
I hope I've been clear.
Mouth
ok mocca tonight I try and see what I can do, in such case if it does not come, I will try to do it again from scratch
then another thing, I need to know if you can change the attributes of the section lines!!! I tried today but nothing....:frown:
then if I put a text you can rotate it by 90 degrees? If you like? ?
Excuse my ignorance, but the environment is new to me
I imagine for "section lines" you mean the virtual plans that cut the figure and not the "zigrinatura" in the jargon section called "camping".
Anyway:
-"section line" the edits by selecting it and then interacting in the attribute palette called "color pen" and changing them color, thickness and type.
-"samping" changes the shape by double-clicking on it and interacting in the last lower window called "material". as attributes instead, once you exit the command, selecting it behaves like for the "section lines"
-"text" to change the corner, during the insertion of the text in the window that will appear you have to go into the green lighter outer frame and click with the mouse, will open an additional window where you can change the angle and possibly insert the edge (box) to the text.
I hope I made myself understand otherwise, ask me if you have any doubts.
for mocca,
hi for the cartiglio I managed using the sketch, as you told me to do, a bit slender but at the end of good result! I managed to make the text samples too
then for the section line changes ok both for style and color (I did not notice the color palette :redface:)
idem for sample section
one thing I noticed, if I have to do many sections the color of the sample if it takes it alone (in some system) or do I have to update the color palette?
for the text ok solved every doubt!! :finger:
what kind of fonts do you use to bring out only the central line of the text and not the edges? I used it all the time ago that I don't remember what the font is called.
(usually discoveries come out by ass shot:biggrin:)
another note:
...usually when I make a mold and load the part of the fix (matrix) and maybe some dowel in it if I make the isometric views always shows me the side with the center ring and I can not go to show the figure contained in it. .this also applies to the dowels I always see the below and never the figure...where instead everything in favor of the punch or (mobile)
thanks mocca and others of the contribution
for mocca,
one thing I noticed, if I have to do many sections the color of the sample if it takes it alone (in some system) or do I have to update the color palette? I don't think there's a priori chance to set the color of the samples. you can select them all first and then change them to your pleasurefor the text ok solved every doubt!! :finger:
(usually discoveries come out by ass shot:biggrin:) I used the aril that doesn't have the edges as you say and to customize it I tilt itanother note:
...usually when I make a mold and load the part of the fix (matrix) and maybe some dowel in it if I make the isometric views always shows me the side with the center ring and I can not go to show the figure contained in it. .this also applies to the dowels I always see the below and never the figure...where instead everything in favor of the punch or (mobile) I didn't understand very well... defaul assonometers can't handle them. You can use mviews instead. if you create them in the assembly you also have the possibility to make small explosions.thanks mocca and others of the contribution
Good job.
Mouth
Hello, everyone.
I'll give you two folders where you can find a great deal of information about the use of patches, including those asked in this topic:
1)top dvd, course folder: here you can find all manuals in Italian, including drawing.
2) subfolder of the tops/program (from version 9.0): in this folder you will find a series of documents in pdf, for the most part in English, where are described all the functions of the top.
That is what I have said, I will answer some questions. . .
to disconnect a file:
1) open the explorer of stumps;
2) select the file you want to unconnect;
3) right-click, select "file entries" in the context menu;
4) the message "all files are connected. skip reconnection?", press "no";
5) the reconnecting window appears, expand the file tree by clicking on the "+";
6) select the file to detach; press the "stack" button;
7) press "Save" to confirm the operation.
to import a cartilage:
1) import the table containing the cartiglio in elt format, using the command "import-from external file-new file";
2) open the newly created table;
3) in the drawing tree, the word "no" appears in the cartilage: this because we are in the presence of a series of entities, but we have not yet created the frame (toptrone card);
4) I press the "no" item with the right mouse button and select "settle tags" in the context menu;
5) the "cartolic station" dialog box appears; select "new cartiglio" from the drop-down menu;
6) I press the "edita cartiglio" button (like a stylized cartilage icon);
7) Now the sketcher environment is activated, in which I can draw a new cartilage. In my case, I want to use existing entities, so...
8) I press the button "Insert entities from a sheet" (package icon with an arrow);
9) select the entities to enter and confirm by pressing the "apply" button (green check mark);
10) insert any missing entities, such as symbolic texts;
11) I press the "Save Cartridge" button (chetto icon), choose the name and path of the file;
12) Cartridge is ready, and available for future use.
13) fine.
Tilt view according to a edge:
1) Suppose we have a beveled cube on the edges. the view in the plant will be a beveled square;
2) to create the tilted view, with perpendicular direction to a bevel, proceed recalling the command "creation view";
3) set the filter "bords and curves";
4) select the bevel to which to refer;
5) click on the sheet on the side where we want to turn the view;
6) fine.
create entities using a specific color (e.g. section lines or sampling):
1) I press the color icon in the toolbar (in the form of bucket);
2) I choose color (e.g. blue);
3) I create the set of entity lines with the chosen color.
change color to a series of entities already present at video:
1) select entities;
2) I press the color icon and change the color;
3) Delegate entities (with the command "pull selection, or ctrl+d).
I hope the descriptions are exhaustive.. In the meantime, I wish you a good evening. ;)
