Crios816
Good morning.
Starting from an autocad cartoon I made the template to use with solid edge.
the various fields of the cartiglio:
- code.
- material
- type of treatment
- description
- revision
- etc.
they auto-compil because I tied them to the fields that are in the "file property" of the part.
the problem arises when I insert multiple sheets, because in the template I inserted the recalls of the properties with this syntax:
%{titolo|r1}
when I put the second sheet in the field of cartilage always appears the title of the part present on sheet 1.
so when I insert 3, 4, 5 sheets the field where there is the call %{titolo|r1} always reads the part present on sheet 1.
Can anyone help me?
Do you know if there's a call that reads the ownership of the part regardless of the sheet number?
- code.
- material
- type of treatment
- description
- revision
- etc.
%{titolo|r1}
Can anyone help me?
