cartilage and compilation
  • Thread starter Thread starter Nada84
Nada84
is it possible to load with autocad mechanical a company cartiglio "block dwg with attributes" and insert it automatically compiled in every part of it?
I do not mean the command enter as a block, I ask if there is a faster method to do this.
I have a similar problem too, I opened a post but no answer, I think you can't do it.
I believe you refer to the command of the annotated menu - title/revision drawing - cartiglio/bordi progetto
it works, with the amtitle command I tell him to replace only the cartilage and change it by reinserting exactly all fields.
of course the labels of the attributes of the cartiglio must be the same otherwise it does not find the reference to the old cartiglio and leaves the blank field.
Okay thank you very much:finger:
