Good morning to all, I would like to remove the coordinates around the cart. when I insert my custom cartilage disappear, when I change the sheet scale, they reappear. Can you help me? Thank you very much
solved: it was a display problem on the original drw file because at the first loading of the sheet the square was active (sheet format -> automatic margin) but it did not appear until the moment when changing some properties of the sheet. now I have actually disabled it (leaving only the 10 mm offset line) and saved as default sheet format.
