ZeroEvil
Good evening to all, I'm at first with inventor and I should create a new cartilage, since that of defeault is not good, only I don't know where to start. . Could anyone help me? Thank you very much
I did, thank you.must be bound.
the four edges of the sheet must be bound to the four points of the white field.... but I do not remember how I did in its time...:redface:![]()
I think I understand, as soon as I can try...then, if you have created the folder with the various boxes where you want the text to be compiled manually (through the "field text" window), you must, in the browser, right click on the name of the folder and choose "change the definition"
Write now for each box that interests you the name of the property you want to enter p.es. material, annotation etc,
n.b.in the Text dialog box, at the type box you have to choose "Input Request".
save and close the change of the cartiglio
in this way your property will be brought back in the field text window. .
Okay, I did, thank you very much.then, if you have created the folder with the various boxes where you want the text to be compiled manually (through the "field text" window), you must, in the browser, right click on the name of the folder and choose "change the definition"
I simply used a hilly bond between the outer lines of my square and the blocked points found in the corner of the sheet.refresh my memory on how to bind the cart.
then to bind the letters and numbers for the coordinates of the sheet you can bind the first and the last to the adjacent edges, then quoted from the first to the last letter, if they are already bound proposes a non-parametric quota, tell him ok and keep in mind that the n° of parameter p.e. "d28"
then quoted from a letter to the next, putting as a quota "d28/n" where n will be the number of letters you are using.
idem for numbers
binding as you say, however, the letter will not remain centered on the box to change the sheet.then to bind the letters and numbers for the coordinates of the sheet you can bind the first and the last to the adjacent edges, then quoted from the first to the last letter, if they are already bound proposes a non-parametric quota, tell him ok and keep in mind that the n° of parameter p.e. "d28"
idem for numbers
Has anyone set this option?always about the cartiglio, how can you set the scale saying so that you automatically take it?
I do not find in the properties of the sheet or design the property to which to bind the parameter.
is it to be created personalized? and how should it be set so that it takes the scale of the view inserted?
I haven't found anything yet.No, just look.
hi davide, can I ask you how you set the scale?I'm going back to the discussion to ask for something that they put me in. I have my cartilage where in the various items to fill out I made all the connections so that automatically there is name, description, scale, weight etc. Is it possible for me to have only the numerical value without the unit of measurement?
