cartilage creation
  • Thread starter Thread starter genesis1975
genesis1975
Good morning, everyone, months ago, I made the cartilage with a person who no longer cooperates with the company, and now it would be a fresh start, but even if I took notes I don't remember anymore.
to learn how to do it neatly you have consulted some texts that explain it well? Where can I get the info?
because the tutorials on the internet don't exhaust the topic and many things don't seem clear to me...I can't find neither texts nor notes on sw...
I do not use the procedure x create sw cartiglio, I created a cartiglio simplement and I saved it as a block that I then insert into the sheet formats.
yes but then you will have created the links so that the description, the codes the material the mass etc. automatically come into the cartiglio.
as written also in a discussion today you can also make copy/paste of a dwg folder.
However if you have the 2012 version you have to draw it completely by hand (or copy it from dwg) because the automatic creation of the cartiglio was implemented in 2018.
Then he doesn't explain at all how the connection to the property of the part is inserted in the model (the written Dollar Sheet..) and how the list of properties is saved in the part so that when I open a part the property has already predefined them. Also there were other shortcomings and inaccuracies that I do not remember now but I will tell you.. .
the written $prp... is already a link to the part, which reads the properties of the part file or drawing. If you write, for example, $prpnomefile you will automatically get the name as you called the file in the windows folder.
If you want to connect a cartoon field to a property you must have created this property in the file.
If you don't create the properties in the file, no one does.
if you try to make constructive speeches spigando where you block, what you do not understand, then well; if instead you complain about the suggested material, which is only a point and that can not fill a knowledge almost nothing goes deep looking in the guide, in the videos, then I don't know how to help you
I remember that to insert the link to a property of the part automatically and not as he says in manual, there is a button that is located right in the window that is open when he speaks of the dollar, even if he does not mention it...I just say that I tried to make the cartiglio following this video but it came out little apart from the blocks because I think it lacks a lot of stuff...I do not want to be rude but if you make a video for good...
Yes, the property must be created in the part, and there must also be a way to save the items I need to me, so when I create a new start already with a grid with already written description, mass thickness code , file name, so that it is only to be filled out.
there must be a way to save the items I need to me, so when I create a new start already with a grid with already written description, mass thickness code , file name, so that it is only to be filled out.
just save the file as a template
i open a new part, I go to write the entries in the property table and then I save it by name and save it as part template. . .after every open part of a new part I must appear the base as starting already with the name I gave him...right?
if I have to delete a part starting base already made instead I have to go to the template folder and delete it?
then I already have a cartiglio made, I want to put on fixed writings, the European symbol, if I change sheet format and then I put them in it save as model he doesn't change anything from the last cartiglio....what mistake?
Maybe I have to change sheet size then edit block...but after the block where you have to save?
Good afternoon,
a few days ago I had to remake the cartilages, I used edit sheet format, and among other things for the modification of the square there is the automatic margin command that is great, while for the cartiglio I drew it and I inserted all the links I needed. I did not make a block and however with copy and paste you can very well carry the cartilage in other formats. a tip, always start from the a4, at least you do the cartilage to the maximum width that you can...... start from an a3 or 2 risks that then you have to remake the cartilage because it does not enter the 'a4
how, with copy and paste after work also the properties?do copy and paste everything, paper and dollar then save as model?
when you are in edit sheet size, draw your cartiglio, do everything you need, then select with the window what you want to copy, ctrl+c, close everything, go to the new square, e.g. an a1, make edit sheet size, ctrl+v and you should have the cutlery done before.
