There are no other ways to insert a textI used the annotation command for the text
How do I know?I had made lines to give the distance from the edges and then I deleted them can be for that
if you attach the cartilage you can check otherwise it is a make assumptions on smoking ideasBut I haven't all become yellow the character is by default black color, do I want to reconnect them from the top?
