cartilage that is lost
  • Thread starter Thread starter giobizio
giobizio
I have a problem on the table:
happens that if I open the design file new and imposed "empty with mask" choosing the format I created with symbol, tables, automatic references and anything else, there is no type of problem.
at the moment when I close this design and re-arpo, known that the logo and the square disappeared while the chart table and the references remained.
I wonder what the problem might be.
the .frm file I created and saved in a folder within the configuration folder, the symbol and the table are also inserted in that table.
you have to put the formats in the default directory or, if you want to manage them in a different directory, you must indicate the address in the config.pro to the option (PHP 4 = 4.1.0)
Thank you, I solved, now I lose only the symbol but this is due to the fact that I can't save it in the directory of symbols.
the logo I created should be saved as a *.sym, but in my computer there is no trace.
I added posts for this topic to an old discussion, so does not weigh down the forum.
(PHP 4 = 4.1.0)r only serves to find the formats manually.
also search_path ...
with which proe finds the format when reopening a drawing.
hinges
