cartilage with overlapping layers
gtsolid
Hello everyone
every time I create a new table (or I open one already started by others)Capture.webpI see that two different layers overlap. but it's an operation I'd like to avoid.
how can I set the active layers by default?
you do it in the starting template and will be functional in the new designs. in existing designs the layers will be activated/unactivated as set when saving
You're referring to .drwdot, aren't you? How do I change them? open in sw and change?
you go to the file types you want to open and choose template and sw redirects you to the folder where he knows that there are templates. modifications and saving
