cartilages sldwrks
  • Thread starter Thread starter simoneo.
simoneo.
hello to all are two days I look for between this forum and the online guide of sldwrks how to carry out the autocompilation of the carts.
I write in the tag, for example, the formula for the weight $prpsheet:{weight} but I did not understand how I have to do to create the autocompilation of the weight according to the piece I insert in the cart.
If you solve the problem you will always have my estimate:d
you will have to assign the "weight" property to the template file; in the value field pull down the drop down menu and choose the item mass. arrivals to the table from file > properties.
I always understand what you're asking.
However,
you are at the first message; as new user would be good what to read the regulation:http://www.cad3d.it/forum1/showthread.php?t=13677explains many things, including "suggest" that is appreciated a brief presentation. .
Anyway welcome:smile:
Mar
I'm sorry you're right. I'm a 22-year-old boy. I'm a simon, and I'm at the first approach with solidworks. Look, I thank you for the answer, but if you have time, I have to ask you for a huge effort, could you tell me step by step (as if I told a monkey) how to do what you said easier? Thank you very much
I took a step forward I managed to give the weight property to the piece and took it now as I connect it to the cart.
