cartridge
  • Thread starter Thread starter mali_fx
mali_fx
I'm struggling with the creation of a cartouche and I don't like one.
a little something I managed to do reading the various posts but it is not yet what I would like!
First of all, I don't read the string ''&rpt.qty' (and I don't understand why'), which is one of the main things I need..., then I posted an image where you see the fields that I would like to parameterize (although for the moment I would like to solve the problem of the parameter'' &rpt.qty'').
place also the file.
I hope someone can find 2 min to take a look at him.
Unfortunately I can't open your format because I have the wf3.
I'll attach my files to you with the relevant strings for the compilation.
excuse but all the strings you put in the various cells, go to recall relative parameters you set in the axieme startpart?
Sorry about the banality, but I'm doing it for the first time.
can you explain to me in 2 words (by making an example) how do you add a paramentro and richamarlo then in the table of the distinct?
You practically have to create a format.
in this you will make all the lines of the cartilage with the fixed values (e.g. drawing, date, code etc.)
then create a table and on the cells go to insert the parameter concerned (which will be a parameter of the start part) with suffix &.
I'll train you my size so you can understand better.
I also included the start part
I managed to do a good 60 % of what I was looking for even if you are far ahead of me and obviously I need time to understand certain mechanisms.
thank you very much to make lollone!
I am also trying to make a cartiglio for myself and for the moment I have already made the file format with its table. the problem arises with relationships and parameters. I created a start part file with references and views, I mean it's complete. But I can't set up relationships. I only care that it appears in the cartilage date, material, my name and weight.
My problem arises with the weight. I wrote in the relationships of the start part peso=mp_mass("") but it always gives me error with red arrow and not yellow and I can not save. I also tried to draw a part and put the same relationship but I had the same result. I noticed something. in your start file in the source box is selected report while I remain selected defined by user and can't change it. I'm stuck and I don't understand where I'm wrong.
you must set a material with relative density active on the start part before creating this relationship.
Hello, Lollone, I'm sorry if I answer you after so much tampo, but I've had some health problems. cmq I did as you said and now everything goes as it should go. Thank you.
