cartridge
  • Thread starter Thread starter Prima
Prima
Good morning.
I've done my company cart, but I have a little problem. passing indistinctly between part and sheet metal there are variables that are in one environment and there are in the other.....
fast example: the thickness of the sheet, or its development cannot be in part environment (unless I create variables of convenient ).
at this point in the cartiglio appears to me instead of sheet thickness and development
" error: no reference ", which I am very unwelcome. is it possible to make sure that in case this condition occurs instead of the error message I appear to be any symbol? type a question mark or similar
In theory if you impose the same entries should show you the value if there is, and if there is no leaves you the empty box, without any error message.
to tell you I to indicate the size on the chart on the variables of the models when starting the item on the exposed name the rhino with thickness.
in the draft the item of call will be %{spessore|r1}.
if I make a par model and do not expose any variable, if I put in the table and I call the voice %{spessore|r1} leaves me the empty box
I've created different files. I had the same problem exposed from before, and more when I recalled the asms I found myself with the kind of material that messed up.
I now have various cartilages, but I wait to pass to the st2 version shortly (I am quite terrified).
Good morning.
Have you tried to create the "thick" variable in the normal.par template? Maybe then you give him a null value or a "-" sign.
so all new parts created from normal.par will inherit that variable.
instead when you create a part from a normal.psm template you will work as usual.
