cartridge
  • Thread starter Thread starter works
works
Hello everyone,
I press that I have tried to search in the existing topics. .
My problem is to create a paper with solidworks 2009 to use as a model for all the tables I have to do. .
I have an autocad crate, but I can't import it. .
How do I do that? ?
Please help me. .
Thank you. .
Hello everyone,
How do I do that? ?
Please help me. .
Thank you. .
I don't understand the problem, you mean that from solidworks you can't import
a very simple dxf or dwg: alcohol:
Hello everyone,
How do I do that? ?
Please help me. .
Thank you. .
obviously you didn't look good (but it doesn't even take long):CERCA CARTIGLIO.webpRISULTATO RICERCA.webpHello
marco
sampon your lunk doesn't work. .
to import a dxf or dwg I can safely, but I can't use it as a base or model to put my tables. .when seleziono creates design on the side then I can't insert my cartiglio as a base...all this in solidworks 2009!! !
to import a dxf or dwg I can safely, but I can't use it as a base or model to put my tables..when seleziono creates design on the side then I can't insert my cartiglio as a base...all this in solidworks 2009!! !
I'm afraid you miss the basics on the cad design.
first you have to create a template with *drwdot extension (c:\documents and settings\all users\dati application\solidworks\solidworks 2009\templates)... impose odds, height character and various bales and save it
as a template.
Then open a new design using the newly created template.
in the choice of format, take one to your case, for example you can
start with a4.
once opened click with ts dx and go to edit sheet format.from there, you can paste into your dxf/dwg previously open always with solidworks.location, change any notes etc... and get out of sheet editing.
the last operation is to save the newly created sheet as "save sheet size".
repeat the procedure for all the formats you want.
I think it is worth noting that the help can help.
ps: the link do sampom worked very well, tried last night.
mike looks at me in truth I am a mechanical maintainer, I have just passed to the office and I am alone, I am trying to use solidworks by self-taught because we are a small company and we can not afford courses for the moment. we are informed for faults but are quite expensive.. I thank you for your advice, I have been very helpful. If I ask stupid questions, thank you again. .
mike looks at me actually I am a mechanical maintainerI've been in the office recently and I'm alone. trying to use solidworks by self-taught because we are a small company and we can't afford courses for the moment. we are informed for faults but they are quite expensive.. thank you for your advice, I was very helpful. If I ask stupid questions, thank you again. .
But... then we're colleagues... :finger:
I know what you're going through.
I've spent the nights on my fucking sw...
Mine didn't want to be a reproach, but a statement... in fact
It was like I imagined.
for every help... also in pm:finger:
Bye. :wink:
Thank you very much.. .
I'm going through a lot of hours... I'm glad to pass because I'm very fascinated... .
Thank you very much for understanding. . .
Hello are luigi libre
as I have told you several times I have begun to use solidworks recently
and "I don't have the basics." for what I understand the carts are created by cad 2d.
then must be imported into solidworks. but for data type n° drawing, code
material, mass etc. that should be taken automatically from part 3d
exist? I mean extensions like <company name="">. and where do I find them?</company>
Who are you talking to?
this discussion is 4 years old....
do not find much done, you have to customize your environment. is very long to write if it has to be clear without basics, this activity requires study by you or counseling a person who knows how to do it.
It is not to cut short, but it is too vast to treat exhaustively in a forum.
Hello everyone,
I recall this discussion as I have a rather annoying problem related to the type of quota set in drvdot, that is, when I insert a block any text and only that of quotas loses the setting that I assigned, all the rest modified in the settings remains ok.
the sw version is 2017.
thank you all for the answers and good Sunday to all.
only that of the quotas loses the setting that I assigned him
What exactly does it change?
The height? the font? formatting?
If you explode the block what happens?
an image, as always, would help. (with some indication of the situation possibly)
changes the font, from what I set "txt" to the default "century gothic" while I just saw the comparison with sw 2016 no problem.
I also try to post pictures.
I also did this test:
I uploaded the dvrdot made with sw 2016 with the sw 2017 version and the problem no longer arises.
if instead I create the dvrdot with 2017 and insert a block any change the font with the default one.
in the beginning the block was a cartiglio without notes only rows and columns, in the dvrtdot I set all font "txt".
What does it matter how old it is? the thing is still current since the problem is about drvdot then.
