cat v5 adimin
deep70
Hello, guys.
forgive the breakup of Fr.... That's what I'm saying. I just changed the pc.. and I lost the mirror that I had done to get into admin on catia, I can make the connection, but I can't change any parameter, in fact it seems that the connection does not open at all the admin mode, but it just catches.
take off here the two links (for catia and for admin) used.
Catia:
"c:\program files (x86)\dassault systemes\b19\intel_a\code\bin\catstart.exe" -run "cnext.exe" -env catia.v5r19.b19 -direnv "c:\programdata\dassaultsystemes\catenv" -nowindow
Catia admin:
"c:\program files (x86)\dassault systemes\b19\intel_a\code\bin\catstart.exe" -run "cnext.exe -admin" -env catia.v5r19.b19 -direnv "c:\programdata\dassasystemultes\catenv" -nowindow
I await your info.. I know that the topic has already been dealt with.. But I really can't get out of it.
thanks in advance to all. .
surely in the enviroment of catia you must set the variable "catreferencesettingpath" with the path of the catsetting of admin , which will be different from that of the catia std .... practically what you will split there will be the path to admin catsetting and the name catsetting_admin.................. cmq if you are looking for the forum you will surely find how to.................. .
