count71 Guest May 9, 2013 #1 Would someone tell me how to delete the display of the graphic tablet on the bottom left? Attachments Immagine.webp 75.7 KB · Views: 43
ferrezio Guest May 10, 2013 #3 in tools\options\general\peripheric 3d you will find the options for the graphic tablet. Hi. Attachments tav.webp 52.3 KB · Views: 15
falonef Guest May 13, 2013 #5 but is it not the same that we know with triangle, circle and line? depends on the module activated? Does anyone have a chance to check?
ferrezio Guest May 14, 2013 #6 the two options that I reported, activate the transformations respectively; of zoom, rotation and translation, while the other activates the area for text insertion, and was that displayed in the figure. Hi.
falonef Guest May 15, 2013 #7 but the one indicated in imggine is a special interface for the surface module?
ferrezio Guest May 15, 2013 #8 no seems to me not a special configuration, it is the gsd module with affinity module and develop. the system has activated the configuration of the tav graf, probably because cont71 uses this device. Hi.
