catalogue fittings
  • Thread starter Thread starter MauroTC
MauroTC
I make this application available, for my fellow designers, hoping to find it useful:interactive catalogue fittingspractically doesn't invent anything that... this contains the database of the size of most fittings used in the industry (those head to weld, according to asme b16.9 and uni en 1253-1), for consultation of which it is usually necessary to browse several pages of catalogs and/or tables; the purpose of the application is to make these dimensions available quickly, also interpreting the legislation that regulates such fittings, with few simple user choices.
In addition to speeding up the data retrieval phase, it also makes it safer to find (always that among the thousands of input numbers did not make any mistakes... :frown:) not having to manually cross the rows of the various tables (e.g., diameters), with columns (e.g., thicknesses), as the program does!
I then preferred to put this resource in this area, as well as in the download area of this site, so that all possible corrections, variations, improvements can concentrate them in a single version of the file, that is what I deposited under the company site, instead of having to go every time to search and replace any replicas here and there...
Thank you very much for the document, you are a magician of excel!
I opened it with openoffice and I hope that's all.
kindly I would like some sites with solid edge lessons thank you... .
hi, some tips since you are new to the forum:
1- as a rule as you should first present yourself, since you have not done so, I recommend that you do it in the appropriate area, if you do not find the solid edge, surely in relief you find the general one in the off topic section:wink:
2- I would say that this post with the topic doesn't make us very clear, as they say in my parts, centered like the cabbages to merenda... so if you need information about solid edge you have to go to the appropriate section
3- Before opening a new discussion it would be appropriate to ensure that the topic has not already been dealt with, because I do not know but I have the feeling that these posts are full of the forum
4- Solid Edge already has from what I know a series of tutorials for software learning... Have you done these exercises yet?
5- With a short google search you will find 1000ia sites with example tutorials etc. of solid edge...
returning instead to the topic in question, I make my compliments to mauro for the material that continues to provide us! thank you!!!! :finger:
p-h
just a little clarification, as with excel 2003 I can not see the various options in the drop down menus related to data for the selection of the fitting... :redface:
Is there any particular setting in the file to edit or am I prevented from using the file? :tongue:
Bye!
p-h
edit: sorry but I didn't change the level of macro protection... What the...
