catalogue
  • Thread starter Thread starter braunfish
braunfish
I am building a welded frame and I do not find in the catalog the rectangular iron tube from 180x60x3 mm, tube that I buy every day on the market.
How to do that?
How to do that?
with standard iso, din or ss, you find it in thickness 4, if you have no mass problems in the compute of weight.......
I have no mass problems, only I can't even find it with thickness 4.
I would not like to have an unveiled catalog, but it seems strange, with inventor 2010
I don't want to have a catalogue not updated, but it seems strange, with inventor 2010
It's not an update problem.
when inventor has been installed must have been installed at least one standard (ansi,din,iso,ss,uni etc.)
now, or maybe you only installed the hold, and then see only the measurements in inches, or
you have installation problems.
check which standards you have installed,otherwise refer to the installation.
a doubt:
for catalogue You mean the content center, don't you?
I forgot, to see what standards you installed, without making too many turns:
in environment together:
command: "Position from content center"
Then on the top left click on the dart next to "filters", you open a list with the planned standards, if there are iso,din,uni,ss you should be able to have your profile, otherwise, if there are no installs.
you mean content center, only that I use inventor in English, so sometimes I try to translate into Italian.
I installed iso, uni, din, and anxious.
I think I'll create my own structural profile and publish it in the content center.
If you have din,uni, you must have profile!
question: does not even find the chassis generator?
