catpart "independent"
  • Thread starter Thread starter Aeon
Aeon
It seems strange that this question has not been asked yet, but I have searched in previous messages and found nothing :p
Is there any way to make the changes within the catproduct (mainly hide the plans and guidelines) not affect even the single catpart?
I would like a catproduct "clean", without all the craps around
If you hide your plans from inside a product you just hide them in the individual parts..................... .
If you want advice, clean the part well before you save it so you have always cleaned the part.................. .
x the constraints you can do so:
tools/options/parameters and measurements/wins and quotas/ filter.......
and then look at the annex............ :wink:
and I know, but since I'm doing very "expanding" drawings I have to continually switch from the product (to check if the pieces connect well) to the part (to change them). and every time I have to put and put up plans.
Hi, maybe you could put the plans that you need
in a specific openbody, or rename them.
so you can hide them and show them quickly, precisely because
You arranged them first.
otherwise you could (sometimes I do so) give it a color very similar to that of the
parts or background so that you can select them immediately without having
all a kind of white "rombi" to annoy the visual.
You may also use those display filters already included (example hide/view sketches - hide/view plans etc...).
you can also "save" the selections made and then call them back. . .
I hope I've got your problem, say hello.
you have to activate the menu of the "selecting groups" which is the one with the envelopes from letter.
first create the group (select the large letter envelope) then given the ok you can or create others or call it back with the command of the small envelopes.
However, it takes more to write it than to do it.
