center di mass
  • Thread starter Thread starter Dottor_Scott
Dottor_Scott
Good morning.
do you know if there is a way to 'mark' the mass center?
or, I would like to see the c.m in drafting automatically,
a quotable point and of course it updates if change
the model.
Thanks for the answer, man!
in fact comes out the reference and I can put, for example,
a csys
Listen, but to see the point in drafting, how would you do that?
model a small sphere and put it in the model?
a csys
put the point (and only that) in a x layer, add the point (and only that) to the reference set that you carry in drafting (if you use the master model technique) then, in drafting active that layer and in the/e view that you want active or disactive that layer with the command layer visible in view. is easier to make than to say.
