challenge cam to comparison
  • Thread starter Thread starter RS4
for rs4
as you may notice from the images I have adopted the strategy of removal of the residual material, automatically, using the function "grossing for levels on hard materials" and omitting the starting rough (specific this for those who do not use cai).
the function of "grossing" I use it a lot because in some cases, unlike the z-level operations, it integrates the past of "emptying / sanding" and thus avoids the break of the tools. It is obvious that it depends on which particular one must work.
with the occasion I greet you
Bye-bye
Hello, dax.
thanks for the answer I noticed that it used sol roughing and then finishing with a super finish, so did you manually not with shooting area? ? ?
So do you agree that this piece can be worked in a variety of ways? ?
for rs4
the strategies adopted are "personal" and manual.
the particular I fully agree, can be worked with multiple strategies.
by experience acquired in mechanical processing there is not only one strategy. you will have to adopt strategies that will exploit in the best possible way the types of tools (inserti or integral md) withnube to the brake spindles (er - strong tightening - hot or cold watering) and/or machine tools (number of high turns, high advances).
the right mix will lead to the realization of a good product.
Bye-bye
Hello, guys, but are the challenges already over?
Hi there.
How are you... the challenges have not ended peacefully:biggrin:
we expect new proposals from other Cammisti colleagues
I take the opportunity to greet everyone and wish good holidays and happy new year to all
powermill 2010 64 bit calculation time less than 5 seconds!!! for the 3-axis test you called
"calcula finishing zig zag step to 45th step 0.1 time calculation if you can without containment profiles"
Hello rs4,
I'm looking for a 5 axle milling expert continuously, I've got a 3.5 mm deep section quarry that wraps at 90° helix.
you can or you know who can verify if this quarry with tool diameter 3 is millable.
I'll be right back.
hello to all I am a user of edge cam....
I find myself very well and is quite practical. . .
If I send you math, you could just check if it's edgy... in my opinion the superfice is "corrupt" and my cam is in crisis... I wanted to know if this was repeated with other systems.
Palo
Hello, send me math, and Monday I'll check if my cam doesn't go into crisis then I'll let you know.
weekend
Hi, Davide, I'll tie you iges files.
the surfaces are positioned with machine origin.
the machine has rotary axis to -360 +360 (table) and head with axis b -110 +110.
theoretically you shouldfresh using only the rotary axis to.
cutter diameter 3 flat or spherical or toric
the part to fresare is the internal quarry.
allego filesotto that name you are on skype.
Hello and thank you
hello on skype you find me with the name
davide.bonometti
tomorrow I try to fresare, but I inform you that skype I use it little!!!
hello good Sunday
Hello rs4,
I'll be right back.
hello paolo like you pass:biggrin:
I'll take a look at him as soon as I can and let you know. . .
if you can give me more material information finish how many past and what kind of strategy you have in mind
using poermill is done with a processing called swarf.
you can use any tool.
processing is done with the side.I only had to break the surf before the radius.
for the rest just one click with the default settings.
giving an inf limit value equal to the milled radius can also end the radius (with a spherical)
for paolo m
I tried today to realize the milling continuously moving only the board with a profiling and with a containment that follows the surface I can perform the quarry.
it was not very easy
for now you are doing the test on an aluminum paticular,
but the original piece will be in stainless steel.
"work for isoparametrics": 45° zigzag with spherical cutter d10 incrementxy 0.1
and surface work tolerance 0.01 without containment profiles
time is calculated: 16.
mass... let us also participate the old summit it v13! :biggrin:
