change appearance in a welded set
  • Thread starter Thread starter Sleepers
Sleepers
I want to change the look of a welded set .iam, and I can't.
I need it because then there is a field that automatically fills with the field in the table <aspetto> of the iam.
for the material I have no problem (the change in the soldering iproperties), but for the appearance things get complicated; the axieme is small, they are three pieces of united sheet, and in all I originally set the same appearance.
logically, I doubt that it is not possible: Why should I be able to assign one aspect to a set of more pieces that could be different from each other?
any workarounds?
Thank you.</aspetto>
Hello, but does not even work by selecting all the components before trying to choose the look from the drop down menu?
theoretically if you have opened a set the curtain of the aspects does not allow you to choose an aspect without first selecting at least one component of the axieme.
I had tried: the appearance of the individual pieces is changed (change the color, but the ipt father remains unchanged), the box shows the new appearance until they are selected all, but deselecting the look box turns neutral.
right, but this change in the axieme cannot then be transmitted to the cartilage (I believe).
to make sure that the information is written on the individual part file you have to change the part itself or open it and change the appearance from them.
the information will never be linked to the aid but to the individual parts.
to make the property appear in the table you can create a custom property together.
