change aspects 2015-2016
  • Thread starter Thread starter Tarkus
Tarkus
as from title,
the aspects on 2016 result to videos completely different from 2015,
the colors are more generally darker and the textures do not always match, especially the scale of the plot.
all this despite using for 2016 the same stuff of 2015 (free of styles, templates etc.)
Now it is not that I do not sleep at night, but every now and then I like to see videos of colors at least similar to the real.
as I had already done when it was changed by autodesk the system of aspects, I tried to vary the settings of the various colors in tools-> appearance, but or I don't remember how it is done, or it seems that it is influential to the changes.
Someone can explain to me in detail, how do you change a look?
Thank you in advance.
I have the same problem, too.
I change the appearance in one part and it is ok, I add the appearance to the library aspects, asks to overwrite and give the ok, but it does not update in the existing parts.
solutions?
I have an additional problem, I can't even change the look, maybe I'm wrong something, but in
tools- > appearance, any face change, e.g. color shade, except but nothing happens in fact... .
I'm beginning to understand where the problem is:
Despite using the same style library of 2015 and the same templates, (obviously migrated), I find that if I open with 2016
the files created with 2015, the aspects are right, if I create a new file the same aspects have a luminance ten times lower.
this with aspects created beyond those own of inventor.
For example, a look created with 2015 has a luminance of 600, which keeps though open with 2016, if I create a new file and put a material with that aspect, I find a luminance of 60.
Sure enough to change it and save, but I can only do it locally, if I try to save the change in the style library, this message comes out to me:
"string resources could not be loaded (and missing) for id 2a 1e (error 25b4e8)".
Why not save? Any ideas?
I attack this old man to figure out how to do it.
After a year I find myself at the usual, I am finally deciding to use and configure 2017, but I get the hive to think about the aspects.
re-epilogando:
with 2016 I used the library aspects and materials of 2015 aiming directly on the folderl design date of 2015, but as already written, beyond having immediately available the materials and colors created, does not give satisfactory results.
Now I would like 2017 to point to its given design folder, but how do you implement my colors and materials without having to recreate them one at a time?
