Ilario
I noticed that in the style of ballpointing, there is a particular ball that besides indicating the number of position of the ball element, can also have additional properties to connect to it. in my case it would be useful in a ball of a welded axieme of a frame where there are more similar tubulars (as often happens in the frames).
looking at the attachment you can see the ball with the two values, the upper one indicating the number of ref. of the detail, while the lower one indicates the quantity together.... well... because I know, but the operator doesn't know if I don't explain it to him, and anyway he can make a mistake. .
I ask if someone already had this need, I would like to have the opportunity to add the qta prefix next to the lower ball.
I noticed that, after placing the ball you can go to change it and "replace it" with a symbol created earlier in the drawing, but it would be to be made pallino for pallino after marking all the pieces... and there is no way to go to associate it in styles (at least I failed).
it would be convenient to recall it in the stages as a style from the curtain (as it is done for tables or for quota styles etc...
Hello and thank you.
