change basic plan at the end of the project
  • Thread starter Thread starter Petrinho
Petrinho
Hello, everyone!
I made a small mistake. When I go to make my part the shadows make me understand that the basic plan is not the one desired (I would like to be xy instead is yz), how can I change it quickly?
thanks to all
I solved!!! if someone needed it. ..substantially just change the view, I explain better:
1- you choose the view you prefer as a basic view...you click on the viewer cube and you set it as the main view
2- This shifts the view so as to display the piece according to what we would like it to be the "top view" (called high by inventor )
3- always from the viewer cube you set that view as view from above... and here is the basic plan will be correct.
thanks to all
Finally a student who asks and does not wait sitting a response and, above all, shares the solution he found.
Good:4425:
