change cart
  • Thread starter Thread starter rubo825
rubo825
Hello, I wanted to know if it is possible to change cartiglio of a drawing made with inventor 2011..
I explain better, I have a drawing made with an old cartilage and I would like to take it on a new cartilage.. Is there any way? of course without losing quotas, notes, tables, etc.
open the new idw and the old ( both open )
go to the browser of the new and cover the cartiglio, move to the old (where you have the quoted design) and in the browser, under "drawing resources ", paste what you copied.
in the same name will ask you whether to overwrite or not, choose yes.
if the name is different, delete the old cartiglio and insert the new, if it is equal does all of him.
Bye.
it seems to me that this thing can be done even in batches if I don't remember badly in programming operations
precisely you have to use the program "guided procedure of transfer of the drawing resources" that is located under tools (at least until 2010 it is called so, I do not know with 2011 if it has changed...).
you can choose all the tables you want to update the cartiglio and a drawing (or a model) that contains the "new" cartiglio, then it automatically modifies.
this method is more convenient if you have to do it for many files.
