danilo_t.
I almost never write on the forum but I follow it.
I often work with a big industry in continuous evolution and I usually need different files of the planimetry (please everyone different projects of plants but same "background") that I would like to remain updated always. Sometimes I need to display it on autocad with all white lines sometimes in color.
if in a new empty file of autocad click on "insert" >" dwg reference..." it gives me the possibility to insert the mother file of the color planimetry on the new design as a block (not editable if not from the mother file of the planimetry), can lower the system that I want for example electric and do the same thing on other plants (new autocad files). in this way if there is a change on the mother plant I make the change only them on the mother file without modifying all the files of all the plants that will be updated automatically.
so I can work in color, but if I have the need to see the block (after the procedure "insert">" dwg reference...") of the white planimetry as I do?
I don't know if I could make me understand. . .
important: I can not work on a single file and assign to each plant a layer because otherwise the single file would become very heavy because it is really a large design, hence the need to have multiple files, each with a type of system but succeeding to change the background or the planimetry once and report the changes automatically on all other files, additional problem that the background sometimes I need to colors sometimes white.I hope someone can help me, if you know different methods to get what I would not hesitate. . .
Say hi, give it to me.
