change color to quotas
  • Thread starter Thread starter roccolaser
roccolaser
hi to all I wanted to ask you if you can change the color to the quotas in solidwoks, I tried but I did not succeed.
you have to go under "options" and "colors"....
Do you want to change them anywhere or just in the drawings? in the second case you can also use the levels.
I wanted to change them in the drawing sheet
If you want to change color for all the drawings you will make, go to options and change the colors of the odds that interest you.1.webpif you want to change the color of one quota to highlight it2.webpotherwise you create a quota level where you give the color you want, select all odds, move them on that level and give them ok.3.webp
Sorry, I wanted to know how to change the odds in the drawing sheet only to some to highlight them, but I can't find line format. .
thanks but and from a very few I use solidworks...:biggrin:
I recommend a reading to the guide and the course of the tutorials present within the program.
You can't hope to learn everything just to hear it.
In addition, an infarination will help you to correctly and clearly post any requests for help and also we, at least, will be able to understand immediately what you are asking.
Mah. .
this compulsive mania to ask in a forum help for issues that are treated perfectly in the help (which however should be used and above all "to use", starting from the funnel seeks... )
It's really unprofitable. since last night when he posted the message he would have already read all the help concerning the quotas and changes of their appearance, in the parts and in the drawings. :cool:
Good connoisseur.. .
Mah. .
You're right. At least a basic knowledge of commands :biggrin:
