change decimal shares list
  • Thread starter Thread starter GianniM
GianniM
from the “.idw” file, when I make a table containing the drawing parts list, the length measurement has 3 decimal digits.
I would like to change this value, removing all decimals. I can change the setting of the single table. but I would like to change the style of the templade to not have to repeat the operation every time.
Unfortunately, in the style editor, I did not understand what value I have to change. Do you have suggestions?
ciauz
does not depend on the styles, but on the model that generates the part (I imagine the structural forms you use) within the contained center.
You should generate any part of that particular family, open it, change the export parameters by putting as many decimals as you want, save, go to the cc editor and replace the family model with what you modified.
I imagine they are the structural forms you use
pictures well.
but then, if I have a 40x40 tube I have to set zero decinals on the size of the length, inside the family parameter?
and if the next time I want 2 decimals I have to rename the family?
logically I think that on a structural form that should be welded, I don't think you need the cents, do you? If you want to put two decimals and set to suppress the final zeros so when you have "full" measures it doesn't show you, while when you have them.
However, if you want the decimals "variable you have to make two separate families with each one the preconfigured model.
In any case, if you also want on carpentry details to put the cents, tell me what carpenter you go that I can respect them that I make a quote:-)
:hahahahah: :hahahahah:
apart from laughter, to stay on the subject, does anyone know if the 2014 rounding function of the quota was added?
I do not understand why in autocad there is and in inv no!:36_1_3:
I don't know, but unfortunately I have to disagree. ... it's a function I hate, in my opinion they should even remove it from autocad! Then it probably depends on the needs, but I never needed it and sometimes it brought me wrong because of someone who used it!
in lattoneria and in carpentry "fine" the half millimeter is still appreciable, but if you bring in the workshop something with a quota, which is, 35.7 instead of 35.5, they start to laugh. It depends on what you have to do.
My problem is that currently, it measures the lengths in mm and puts me 3 decimals after the comma. Too many. I would like to remove all the values after the comma. without changing manually.
I exhume this post because with the search I did not find answer.
how do I set the elimination of the 0 finals?
whether to recover a quota from the model must be set even in the latter or just set it in the table?
dx key on the quota, change style quota.
opens a curtain where there is "display", choose the snacks you want, save and exit.
only applies to the table on which the change is made.
If you want it on all the tables, open the template and do the same on that file, which then will be the basis for the future harvests at the table.
in the parameters panel (fx) where you put the check for export , making the right button with the mouse ,
appear settings to format the field so as to have the custom iproperties
As you wish. .
That's what I do for me. ocio however also to the date design folder that contains the quota styles.
