change extruded polygon position
  • Thread starter Thread starter archiwalters
archiwalters
Greetings to all.
I simplify the problem to try to be clearer:
-I build my beautiful 3d model consisting of extruded polygons:smile:
-translo/ruote model
-published one of the solids to change it and displays the starting range in its original location.
the thing is rather annoying because, in changing the figure, I do not have the possibility to hook me or to use polygons/solids moved or drawn subsequently to move the model:frown:
is it possible to ensure that the original polygon is moved during the movement of a solid and that the latter, by editing the solid, is displayed in the new position?
I don't know if I understand:confused:
thanks for the attention.
walter
the two-dimensional primitive that generates the solid keeps the coordinates of origin. but when you edit a solid, objects are still displayed alongside, at least on 2011. I don't remember...
I do.
I do.
Hello, lory.
Unfortunately, no! the only primitive is displayed in the original location.
sum them up or remove them designed surfaces after moving becomes a real problem!! !
It's true, I've checked now on 2010.
However, the sum and subtraction operations can be done directly on solids, without necessarily editing them.
I do.
I asked myself a similar question in order to manage the 2d in assonometric position. I think it is not possible on versions 2009 and 2010.
