change function
  • Thread starter Thread starter blubossa
blubossa
in the 2007 version when I wanted to change a function I clicked on the function then right button and decided whether to change the sketch or function.
I just gave an eye to the 2009 version and if I click on a 1-time function I can change it directly........... can you bring it back to the old operation? ?
I hope I've been clear.
I don't think so. I suggest you get used to the new interface because more productive when you get used to it.
also in 2009, click on the funzine (in the tree or on the screen), and you will find the context menu with the icons, among other but first in sight, of "modification feature", "modification sketch"
is it not that by chance you are proud of the possibility of real-time modification of the function by clicking in graphic area using instant3d commands? if that you can turn it off; you should default the button in the function bar
Can you bring it back to the old operation? ?
if you disable instant3d you remain the context menu with sketch editing and feature change as in 2007 only you have icons and is more comfortable.
Fucking... :rolleyes:
