change geometric group
  • Thread starter Thread starter Mastello
Mastello
good morning to all, this command has the limit that you can change of geometric group only 500 elements at a time otherwise if you pre-select more than 500 by making dx mouse no longer appears the option to change the geometric group.
Is there any setting to change in order to increase the maximum limit?
I thank you in advance for your feedback. Good Sunday
If you select a high number of elements (how did you understand that they are more than 500?????) the option of changing the geometric group does not appear anymore in dx mouse...
but it is always accessible from the menu/modification/modification geometric group and I believe without limit of elements (I made a test with 4,000)
you can customize the button by transporting it to your toolbar (menu/visualize/barra of tools/personality/commands/all commands/modifies geometric group and strascini)
Let me know.
I did some evidence and so I found the limit of 500, tomorrow I try in the office and let you know
Hi, gianni55, I tried today. If they pick more than 500 items and go to the edit menu, I do not see the submenu selected elements/modification geometric group. I used your second advice and I took out the command and attached it to an existing toolbar and I also dissected a button to call it back quickly, I thank you very much, I avoid doing many passages playing with unseen space thanks
