change name property
  • Thread starter Thread starter Sp4rk0
Sp4rk0
Good morning.
I wanted to know if it is possible to change the name of a property, when I create a delimiting rectangle creates the property straight length of total delimitation..... instead I would like it to be called length, because the string length is what reads the pdm.
I have to enter the property from planning units in each file every time, if instead it created me already the property would be better.
You can put it in the part.prtdot you use when you create the file. But first you have to make a solid, then put the function (which I don't remember) that creates the delimitation rectangle, then put the equal lenght function etc etc and then delete all the functions and save the part .prtdot
