change of link between catdrawing and catpart
  • Thread starter Thread starter RICU
RICU
I have a catdrawing tied to a catpart, in modifying the link reassigning a new catpart I have an error message saying: "The link did not accept the document." I have noticed that you have already dealt with similar situations but I have not understood how to use these suggestions to my case.
Thanks :confused:
I'll try to explain why:
If the two .catprts documents do not have the same uuid (and here I invite you to do a search in the forum) you will not be able to replace it in your drawing.
to always have the same uuid you have to use the command open and then save as.
I doubt you used this methodology.
I recommend that you use it right now to avoid this type of problem
for the moment thanks to the answer, I try to follow your directions and then I will make myself feel.
According to this, the problem I think was born at the time when they asked me to make the table before having the start files of the customer. once received I copied the 3d in the catpart but then you can't connect the 2d to the 3d. I tried to copy also the views in the customer's catdrawing but keeps the links to the old table and the old 3d. At this point I think I will have to make the table again!! :frown:
Hello, falonef,
Thanks for the tips, I finally had to make the table again. I wished, however, to thank those who provide other time and knowledge. Also in other situations I used the forum to solve some work problems.
well if you use my method now you can change the links of drawing cin another catpart and you will see that there is no problem.
try to believe
