change of measurement units
  • Thread starter Thread starter Guido95
Guido95
hello to all:) I am working on the project of a reducer with creo parametric. only now (very much with the project) I realized that I worked with the unit of measurement in that. is there a way to pass in mm and above all there is a way to transform them all in mm maintaining their value? In the sense I have a diameter of 100 in and I want it to be 100 mm without having to reset everything. thank you very much for the attention:)
yes x luck in model property-----> unit size change there is the possibility to interpret 1 in as 1 mm :)
